goldenyears
#1 Posted : Thursday, June 4, 2020 5:55:56 PM(UTC)
goldenyears
Indonesia
Dear all,
I have question, does it possible to change camera input using data change,
I have mini quiz game that have API on Player seat, so every player on the screen, API will fetch Seat code from game, then I need to show player cam from that seat.
so I using excel as data source, and in the excel there is 2 sheet
sheet 1 will lock to data change source and sheet 2 as reference
for example:
Sheet 1
Sheet 2
The objection is automation input using data change, so I didn't need to operate this pc because the entire operation controlled by API from game to change the camera.
since I dumb with programming, if possible can you guys give me some help with this problem.
#2 Posted : Thursday, June 4, 2020 6:19:23 PM(UTC)
Originally Posted by: goldenyears Go to Quoted Post
Dear all,
Yes
You are willing to learn it or you want someone else to do it for you ?
There are many similar questions about responding to data changes in this forum to look into even script examples
goldenyears
#3 Posted : Thursday, June 4, 2020 6:23:09 PM(UTC)
goldenyears
Indonesia
Dear all,
Yes
I willing to learn but maybe need times and lot of question
#4 Posted : Thursday, June 4, 2020 6:36:24 PM(UTC)
It's pretty simple really (no there is no direct way but with some logic there i a workaround)
What shortcut would need to be used to achieve the result with the selected input ? (check the shortcut list ) example the input chosen should be overlayed or cut etc)
A title input content responds to a data change from your data source and a script can read the content of the title and instruct a "shortcut" command.
Check out the "scripting for dummies" post in this forum first, there are a few examples in there that would suit you with a bit of adaptation
goldenyears
#5 Posted : Friday, June 5, 2020 1:17:11 PM(UTC)
goldenyears
Indonesia
which one? can you provide me example script? I cannot found what i need in Scripting for Dummies
stigaard
#6 Posted : Friday, June 5, 2020 4:14:10 PM(UTC)
stigaard
Denmark
Do you expect other people to do your work??
thanks 1 user thanked stigaard for this useful post.
doggy on 6/5/2020(UTC)
goldenyears
#7 Posted : Saturday, June 6, 2020 9:55:22 PM(UTC)
goldenyears
Indonesia
no no no, I didn't ask to do my work, I ask example, like source code so I can learn how it's works,
#8 Posted : Sunday, June 7, 2020 1:00:18 AM(UTC)
That's what they are in the "Scripting for Dummies", examples
Those are never exactly what you want but give you hints on how to's. Most of them have a little bit of explenation within
There is one that contains reading the content of a title textbox (That will be auto updated by your data source )
use that result to decide to give the command (multiple examples there )
Read the helpfiles for a list of the possible commands (same as for shortcuts) , check which shortcut you would need if you did it manually and use that in your script
as you will need to regularly check on the data change , read up on vb.net coding on how to loop an test for situations ( polling to see when the textbox content changes)
you said you wanted to learn :-)
