Changing input through data change
Dear all, I have question, does it possible to change camera input using data change, I have mini quiz game that have API on Player seat, so every player on the screen, API will fetch Seat code from game, then I need to show player cam from that seat. so I using excel as data source, and in the excel there is 2 sheet sheet 1 will lock to data change source and sheet 2 as reference for example:   The objection is automation input using data change, so I didn't need to operate this pc because the entire operation controlled by API from game to change the camera. since I dumb with programming, if possible can you guys give me some help with this problem.
Joined: 12/27/2012(UTC) Posts: 5,537  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Yes Quote:since I dumb with programming, if possible can you guys give me some help with this problem. You are willing to learn it or you want someone else to do it for you ? There are many similar questions about responding to data changes in this forum to look into even script examples
Yes Quote:since I dumb with programming, if possible can you guys give me some help with this problem. You are willing to learn it or you want someone else to do it for you ? There are many similar questions about responding to data changes in this forum to look into even script examples I willing to learn but maybe need times and lot of question
It's pretty simple really (no there is no direct way but with some logic there i a workaround)
What shortcut would need to be used to achieve the result with the selected input ? (check the shortcut list ) example the input chosen should be overlayed or cut etc)
A title input content responds to a data change from your data source and a script can read the content of the title and instruct a "shortcut" command.
Check out the "scripting for dummies" post in this forum first, there are a few examples in there that would suit you with a bit of adaptation
Originally Posted by: doggy  It's pretty simple really (no there is no direct way but with some logic there i a workaround)
which one? can you provide me example script? I cannot found what i need in Scripting for Dummies
Originally Posted by: goldenyears  which one? can you provide me example script? I cannot found what i need in Scripting for Dummies
Do you expect other people to do your work??
 1 user thanked stigaard for this useful post.
Originally Posted by: stigaard  Originally Posted by: goldenyears  which one? can you provide me example script? I cannot found what i need in Scripting for Dummies
Do you expect other people to do your work?? no no no, I didn't ask to do my work, I ask example, like source code so I can learn how it's works,
That's what they are in the "Scripting for Dummies", examples Those are never exactly what you want but give you hints on how to's. Most of them have a little bit of explenation within There is one that contains reading the content of a title textbox (That will be auto updated by your data source ) use that result to decide to give the command (multiple examples there ) Read the helpfiles for a list of the possible commands (same as for shortcuts) , check which shortcut you would need if you did it manually and use that in your script as you will need to regularly check on the data change , read up on vb.net coding on how to loop an test for situations ( polling to see when the textbox content changes) you said you wanted to learn :-)
