I realize that the D-Link DCS-4603 is not among the list of compatible PTZ cameras supported by vMix. It does, however, support RTSP and H264 AAC-HBR protocols as specified by vMix. I've read through the documentation found it in need of updating so I turned here, to the forums to find out how to configure the imput.
I have the camera configured and in vMix I've added selected Stream/SRT. From here I have selected VLC. I think I have the URL figured out (rtsp://192.168.1.11:554/user=admin&password=password&channel=1&stream=0.sdp ?real_stream) from what I've picked up here in the forums. What is the "Options" box for?
Anything else I should be looking for?
Thanks if advance. David
Been playing with this for a couple of hours now. If anyone would like to know - Yes, the D-Link DCS-4603 will work with vMix. Here's how:
1. Add input 2. Select Stream/SRT 3. Use VLC 4. Enter the URL in this format, rtsp://192.168.0.101:554/live2.sdp 5. If you have not done so, you'll need to set authentication on the camera to None
This will give you a camera feed from this device. I have tried all the PTZ options, the only one that seems to connect is Test PTZ although it did not actually move the camera. But then again, I haven't been able to move it from the web interface either. More testing tomorrow and maybe I'll have this ready to go for Sunday's service.
