Joined: 5/10/2020(UTC) Views messages in topic : 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
When I run this script, instead of adding my director mic (input 50) to the G bus (virtual green room), it adds it to the Master bus -- where it never should be. I'm a novice at scripting, so maybe I'm just doing something wrong. Code:
'*** Move Everyone to Green Room ***
'Take Announcers off Master Bus
Function=AudioBusOff&Input=3&Value=Master
Function=AudioBusOff&Input=4&Value=Master
Function=AudioBusOff&Input=5&Value=Master
'Change Listens to "G" Bus
Function=VideoCallAudioSource&Input=3&Value=BusG
Function=VideoCallAudioSource&Input=4&Value=BusG
Function=VideoCallAudioSource&Input=5&Value=BusG
'Turn Mics On
Function=AudioOn&Input=3
Function=AudioOn&Input=4
Function=AudioOn&Input=5
Sleep 1000
'Add Director to "G" Bus
Function=AudioBusOn&Input=50&Value=BusG
I have confirmed that it's that last line of code that's doing it by commenting it out. Is there something about my syntax? When I do the following, it undoes it, only furthering my confusion. Code:
Function=AudioBusOff&Input=50&Value=Master
Try swapping out "Value=BusG" to "Value=G"
In the Shortcut Function Reference page is says for function AudioBusOn: M,A,B,C,D,E,F,G Value=Bus. Meaning that the value you provide should be M, A, B, C, D, E, F, or G.
perhaps you need also
Originally Posted by: stigaard  Try swapping out "Value=BusG" to "Value=G"
In the Shortcut Function Reference page is says for function AudioBusOn: M,A,B,C,D,E,F,G Value=Bus. Meaning that the value you provide should be M, A, B, C, D, E, F, or G. Hi, thanks for your reply! Update! I must have done something wrong in testing. Value=G did work. Perhaps I was confused because the VideoCallAudioSource function expects BusA, but AudioBusOn expects just A. Not sure why it was turning on the master bus when I had it formatted wrong, though. Thanks to everybody for your help!!!
Originally Posted by: xaver  perhaps you need also
Function=AudioBusOff&Input=50&Value=Master Hi, thank you! I have done this, which takes my mic back off the Master bus... but it still isn't on Bus G.
Originally Posted by: Geoff B  Originally Posted by: xaver  perhaps you need also
Hey xaver, thanks for shaing that video!
I have had my talkback working for some time, which is what Tim shows in this video. Actually, this video was posted a couple of days after I asked a question about the workflow, which makes me wonder if I inspired this video :).
The VideoCallAudioSource function is working as I would expect. It's the AudioBusOn and AudioBusOff functions that are giving me fits. Within the same script, they'll both do what I expect for one source, and the opposite of what I expect for another.
Works for me very well on vMix 22
Function=AudioBusOn&Input=1&Value=B
Function=AudioBusOff&Input=1&Value=Master
Function=AudioBusOn&Input=2&Value=A
Function=AudioBusOff&Input=3&Value=A
(not Updatet yet to vMix23)
