Help with timers...multiple start time options - FIXED
Joined: 5/16/2020(UTC) Posts: 8  Location: Philadelphia Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hi there,
I'm tying to configure different 2 timer options, using the same input source #1: 2 min countdown #4: 4 minute countdown
Currently using Title / GT timer
While I'm able to save the different displayed start times (using the big + sign) Right clicking on the timer input, I see both saved start times 4:00 & 2:00, but they always keep counting down from what ever time was last entered in the settings dialog box.
I'd be grateful if anyone has a solution for this one.
thanks, Michael
@ Indrestudios
If I have understood you correctly, this is not possible with the "presets" under the + and - icons in the Title Editor since the "Duration" is already pre-configured in the Timer settings. I would instead recommend creating two Shortcuts to configure the "Duration" accordingly with the function "SetCountdown". Otherwise, you have to configure the "Duration" in settings manually.
@ IceStream
Thank you! That worked perfectly. Created 2 shortcuts, assigned to 2 streamdeck keys and we're off and running. Actually faster than right clicking the timer to pull up different options.
thanks, Michael
