Indrestudios
#1 Posted : Thursday, May 21, 2020 1:13:06 AM(UTC)
Indrestudios
Hi there,
I'm tying to configure different 2 timer options, using the same input source
#1: 2 min countdown
#4: 4 minute countdown
Currently using Title / GT timer
While I'm able to save the different displayed start times (using the big + sign)
Right clicking on the timer input, I see both saved start times 4:00 & 2:00, but they always keep counting down from what ever time was last entered in the settings dialog box.
I'd be grateful if anyone has a solution for this one.
thanks,
Michael
#2 Posted : Thursday, May 21, 2020 11:29:18 AM(UTC)
Views messages in topic : 2,693
@ Indrestudios
If I have understood you correctly, this is not possible with the "presets" under the + and - icons in the Title Editor since the "Duration" is already pre-configured in the Timer settings.
I would instead recommend creating two Shortcuts to configure the "Duration" accordingly with the function "SetCountdown".
Otherwise, you have to configure the "Duration" in settings manually.
Indrestudios on 5/21/2020(UTC)
Indrestudios
#3 Posted : Thursday, May 21, 2020 9:08:44 PM(UTC)
Indrestudios
@ IceStream
Thank you! That worked perfectly. Created 2 shortcuts, assigned to 2 streamdeck keys and we're off and running. Actually faster than right clicking the timer to pull up different options.
thanks,
Michael
