clc
#1 Posted : Thursday, May 21, 2020 4:20:43 AM(UTC)
clc
I just got an xBox controller for PTZ control and other shortcuts. I can not use 'Find' to make any shortcuts and the template shortcuts don't work either. Is there something I need to do to get vMix to see the controller. I was looking in windows settings and moved the joystick and the focus moved from box to box in Windows settings so there is input from the controller.
Thanks Keith
ask
#2 Posted : Thursday, May 21, 2020 9:38:04 AM(UTC)
ask
Thanks Keith
Did you import the template?
https://www.vmix.com/hel...PTZControlShortcuts.html
clc
#3 Posted : Thursday, May 21, 2020 10:14:43 AM(UTC)
clc
Thanks for the reply. Yes I imported the template. I also tried to use the find feature but nothing shows up. Just in case it matters I am still using the trial package. Plan to purchase the 4k version shortly.
Keith
clc
#4 Posted : Thursday, May 21, 2020 11:22:33 AM(UTC)
clc
Finally solved this. I had to have the controller plugged in before I opened vMix.
Keith
ask
#5 Posted : Thursday, May 21, 2020 3:19:39 PM(UTC)
ask
Yes, This is normal for most external controllers e.g x-keys. Good to hear you have solved your issue.
