MomentAV
#1 Posted : Tuesday, May 19, 2020 12:08:22 AM(UTC)
MomentAV
Spain
Hi Everyone,
I was broadcasting on vimeo a few weeks ago but recently I got an error message when trying to broadcast on their platform, I have talked to them and I have opened some ports but without any results, I leave you here the error that VMIX gives me:
FFMPEG1.Exited
Report written to "C:\ProgramData\vMix\streaming\streaming1 20200518-160723.log"
ffmpeg version 3.3.git Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-nvenc --cpu=i686
libavutil 55. 76.100 / 55. 76.100
libavcodec 57.106.101 / 57.106.101
libavformat 57. 82.101 / 57. 82.101
libavdevice 57. 8.101 / 57. 8.101
libavfilter 6.105.100 / 6.105.100
libswscale 4. 7.103 / 4. 7.103
libswresample 2. 8.100 / 2. 8.100
libpostproc 54. 6.100 / 54. 6.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 417307.816000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1920x1080, 25 fps, 25 tbr, 10000k tbn, 10000k tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
[tcp @ 054ed760] TCP Buffer has been set to 10320896 bytes
[dshow @ 02907f20] real-time buffer [vMix Video YV12] [video input] too full or near too full (63% of size: 128000000 [rtbufsize parameter])! frame dropped!
rtmp://rtmp-global.cloud.vimeo.com/live/2adc0b3c-295f-49fe-9db5-f6ec226c6518: I/O error
Captura studio6.PNG (13kb) downloaded 1 time(s).
I can broadcasting in another platforms like Facebook and another RTMPS.
Anybody can help? Thank you!
Vince Beck
#2 Posted : Tuesday, May 19, 2020 4:30:37 AM(UTC)
Vince Beck
This sounds more like a Vimeo problem. Or a VPN/Firewall issue? Is that still happening?
MomentAV
#3 Posted : Tuesday, May 19, 2020 8:11:04 PM(UTC)
MomentAV
Spain
That still happening, Im already talking with Vimeo for a few weeks and they dont give me any solution, im going to try with a demo account to check if it is problem of my account (vimeo issue) or if im doing something wrong, im not using any VPN, im tried to deactivate all firewall, two differents networks and nothing works. The most extrange is I can broadcasting one month ago.
Casey
#4 Posted : Monday, June 1, 2020 10:21:43 AM(UTC)
Casey
I've had the similar problem with Vimeo, a potential work around is to set the webcam input in Vimeo to your vMix output and connect the audio with a virtual cable. Then all you have to do is turn on the external output in vMix. Just remember that going live and ending the stream will be controlled on the Vimeo back end not vMix.
MomentAV
#5 Posted : Friday, June 5, 2020 8:19:32 AM(UTC)
MomentAV
Spain
It doesnt work, its an issue with Vimeo and my account, i think they didnt know what is happening, i think they have to reset my account.
newmans
#6 Posted : Sunday, June 7, 2020 6:33:17 AM(UTC)
newmans
Germany
i had the same problem a few weeks ago.
My problem at the end was that in the streamsettings at the 2nd Stream, and i don´t know why,
there was Stream 1 Multi-Bitrate activated, after setting to none everything worked again.
