gokily
#1 Posted : Sunday, May 17, 2020 8:50:30 PM(UTC)
gokily
Croatia
I have difficult time understanding why sometimes this option seems fine for example:
Naming A,B,C
Result A1,B1,C1
But sometimes it gives
Naming A,B,C
Result A.1,B.1,C.1
Is it some formating issue? Am I missing something?
#2 Posted : Sunday, May 17, 2020 9:00:54 PM(UTC)
You have been a member since:: 12/27/2012(UTC)
looks to be dependent if one is using an excel source or xml source for example (at least here it does)
gokily
#3 Posted : Sunday, May 17, 2020 9:16:12 PM(UTC)
gokily
Croatia
Its an excel xlsx, I really can not figure it out
Sometimes its random, but I cannot depend on it because maybe it can mess the data (GT Template) while on air. It happened pre show one time, so I'm not using it. I just want to figure out what is causing it
This are both screenshots from Vmix database
#4 Posted : Sunday, May 17, 2020 9:30:58 PM(UTC)
Suggest you report/ask this to vMix and report back here , they know the details
gokily
#5 Posted : Monday, May 18, 2020 12:28:40 AM(UTC)
gokily
Croatia
I've finally managed to find and fix the issue, well its more a workaround
The problem seems to be total number of columns and rows, even in some software you cannot change that but in google sheets you can remove them.
After limiting number of columns and rows it works every time without ANY issue.
The problem I had was with excel, google sheet, csv everything.
After limiting (its mostly connected to columns rather than rows) everything is fine. Tried it 30 times, created new templates. Perfect every time.
Even with downloading it as xlsx works (previously nothing).
gokily
#6 Posted : Monday, May 18, 2020 4:38:21 PM(UTC)
gokily
Croatia
Still not fixed but the issue is tracked down, if there are more than 10 columns defined it gets bugged. In the project above if I add 3 more columns naming becomes Name.1 Name.2 etc. I've reported the problem to support.
Edit: Got respond from the support, this behavior is by design to avoid conflict with naming.
vighneshacharya
#7 Posted : Thursday, April 17, 2025 3:42:30 PM(UTC)
vighneshacharya
India
yes thanks this will helps a lot.
i faced this issue when i preparing team squad graphics i thought this issue was from my linked excel data.
thanks for the help!!
so we need to include . (dot) in between in gt graphics if column is more than 10
