Datasources use first row as name issue (convert rows to columns)
Joined: 2/2/2019(UTC) Posts: 13  Was thanked: 2 time(s) in 1 post(s)
I have difficult time understanding why sometimes this option seems fine for example: Naming A,B,C Result A1,B1,C1 But sometimes it gives Naming A,B,C Result A.1,B.1,C.1 Is it some formating issue? Am I missing something?
looks to be dependent if one is using an excel source or xml source for example (at least here it does)
Its an excel xlsx, I really can not figure it out  Sometimes its random, but I cannot depend on it because maybe it can mess the data (GT Template) while on air. It happened pre show one time, so I'm not using it. I just want to figure out what is causing it This are both screenshots from Vmix database
Suggest you report/ask this to vMix and report back here , they know the details
I've finally managed to find and fix the issue, well its more a workaround The problem seems to be total number of columns and rows, even in some software you cannot change that but in google sheets you can remove them. After limiting number of columns and rows it works every time without ANY issue. The problem I had was with excel, google sheet, csv everything.  After limiting (its mostly connected to columns rather than rows) everything is fine. Tried it 30 times, created new templates. Perfect every time. Even with downloading it as xlsx works (previously nothing).
Still not fixed but the issue is tracked down, if there are more than 10 columns defined it gets bugged. In the project above if I add 3 more columns naming becomes Name.1 Name.2 etc. I've reported the problem to support.
Edit: Got respond from the support, this behavior is by design to avoid conflict with naming.
yes thanks this will helps a lot. i faced this issue when i preparing team squad graphics i thought this issue was from my linked excel data.
thanks for the help!!
so we need to include . (dot) in between in gt graphics if column is more than 10
