LiveStreamingJamaica
#1 Posted : Monday, May 18, 2020 1:27:55 AM(UTC)
Jamaica
Was thanked: 3 time(s) in 1 post(s)
I'm curious as to the Advantages and/or Disadvantages with the 2 Syntaxs below. They both do the same thing but wondering if one is better (or worse) for resource utilization.
API.FUNCTION vs FUNCTION=
Examples
API.Function("SetOutput4", "Image_Name")
Function=SetOutput4&Input=Image_Name
#2 Posted : Monday, May 18, 2020 1:50:31 AM(UTC)
Examples
No idea resource utilization but I do believe its easier to use the API.Function to replace (or combine) parts with variables used in a script
#3 Posted : Monday, May 18, 2020 2:19:50 AM(UTC)
Jamaica
It's only easier as you don't have to type all the "=" and "&" signs in the line.
#4 Posted : Monday, May 18, 2020 2:23:53 AM(UTC)
can you replace the say image_name with a variable or add a variable to a string to have a more logical en streamlined coding within the end less line for repeated code
#5 Posted : Monday, May 18, 2020 2:50:41 AM(UTC)
Jamaica
if you understand and know VB almost anything is possible. However; you are asking questions and responding to my post and not understanding my post/question.
I merely want to know if there is any ADVANTAGE/DISADVANTAGE in using the SYNTAX "API.FUNCTION" vs "FUNCTION="
I'm not about to give you instructions on how to create/write Scripts from this Post.
#6 Posted : Monday, May 18, 2020 3:06:08 AM(UTC)
Arguing?
I merely gave an opinion on what i found be easier and that i had no idea regarding your original in terms of resource utilisation to which you countered that the easy argument is about typing
now you claim i dont understand while changing your question to ADVANTAGE/DISADVANTAGE in using the SYNTAX
if you combine questions expect combined answers
as to resource utilization why not ask the developer , he would be best to give you that answer
no need to
#7 Posted : Monday, May 18, 2020 3:20:15 AM(UTC)
Jamaica
HAVE A NICE DAY!
