Joined: 5/7/2020(UTC) Posts: 7  Location: St Ann Was thanked: 3 time(s) in 1 post(s)
I'm curious as to the Advantages and/or Disadvantages with the 2 Syntaxs below. They both do the same thing but wondering if one is better (or worse) for resource utilization.
API.FUNCTION vs FUNCTION=
Examples
API.Function("SetOutput4", "Image_Name")
Function=SetOutput4&Input=Image_Name
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: LiveStreamingJamaica  I'm curious as to the Advantages and/or Disadvantages with the 2 Syntaxs below. They both do the same thing but wondering if one is better (or worse) for resource utilization.
Examples
Function=SetOutput4&Input=Image_Name No idea resource utilization but I do believe its easier to use the API.Function to replace (or combine) parts with variables used in a script
It's only easier as you don't have to type all the "=" and "&" signs in the line.
Originally Posted by: LiveStreamingJamaica  It's only easier as you don't have to type all the "=" and "&" signs in the line. can you replace the say image_name with a variable or add a variable to a string to have a more logical en streamlined coding within the end less line for repeated code ??
if you understand and know VB almost anything is possible. However; you are asking questions and responding to my post and not understanding my post/question.
I merely want to know if there is any ADVANTAGE/DISADVANTAGE in using the SYNTAX "API.FUNCTION" vs "FUNCTION="
I'm not about to give you instructions on how to create/write Scripts from this Post.
Arguing? I merely gave an opinion on what i found be easier and that i had no idea regarding your original in terms of resource utilisation to which you countered that the easy argument is about typing now you claim i dont understand while changing your question to ADVANTAGE/DISADVANTAGE in using the SYNTAX if you combine questions expect combined answers as to resource utilization why not ask the developer , he would be best to give you that answer Quote:I'm not about to give you instructions on how to create/write Scripts from this Post. no need to
