StryderTV
#1 Posted : Friday, May 15, 2020 8:19:30 PM(UTC)
StryderTV
I have an IP camera that has both video and audio.
If I use Add Input, Stream/SRT, RTSP over TCP and enter
rtsp://192.168.1.11:554/user=admin&password=&channel=1&stream=0.sdp ?real_stream
I get the video but no audio as seen in the left pic
If I use VLC
with the same stream parameters I get the right unusable picture but I get the audio. (I did download VLCforvMIX)
Yes I know I could use the video from one and the audio from the other but I am trying for a single input solution.
Any thoughts much appreciated?
xaver
#2 Posted : Friday, May 15, 2020 9:57:47 PM(UTC)
xaver
whats about RTSP over UDP?
StryderTV
#3 Posted : Friday, May 15, 2020 10:52:42 PM(UTC)
StryderTV
Hi Xaver
Nope, didn't work, I tried all the other settings and only those two worked at all.
StryderTV
#4 Posted : Friday, May 15, 2020 10:53:46 PM(UTC)
StryderTV
I am assuming with the RTMP stream I am going to have to specify the audio stream separate to the video stream somehow?
xaver
#5 Posted : Friday, May 15, 2020 11:12:02 PM(UTC)
xaver
when you open the RTSP direct with VLC Player, everything is working?
which Codecs are shown in VLC
StryderTV
#6 Posted : Saturday, May 16, 2020 2:09:43 AM(UTC)
StryderTV
If I just use the normal VLS I only need to select the URL 192.168.1.11:554 and it then asks for username and password and after a few seconds it all opens, video and audio. The pic shows the settings.
xaver
#7 Posted: : Saturday, May 16, 2020 2:52:10 AM(UTC)
xaver
have you tried
rtsp://user:pw@192.168.1.11:554/channel=1&stream=0.sdp
rtsp://user:pw@192.168.1.11:554/&channel=1&stream=0.sdp
or some similar combinations in vMix?
StryderTV
#8 Posted : Sunday, May 17, 2020 12:08:50 AM(UTC)
StryderTV
I will try that and get back to you, many thanks.
StryderTV
#9 Posted : Sunday, May 17, 2020 12:33:44 AM(UTC)
StryderTV
I tried both of those and got a 401 and a black screen, thanks anyway. I am still researching RTSP.
