Hardware Compatibility
IP Camera gives video via RTSP and audio via VLC?
Joined: 10/15/2018(UTC) Posts: 17  Location: Worcester, UK Was thanked: 1 time(s) in 1 post(s)
 IMG_6662.jpg (207kb) downloaded 2 time(s).I have an IP camera that has both video and audio. If I use Add Input, Stream/SRT, RTSP over TCP and enter rtsp://192.168.1.11:554/user=admin&password=&channel=1&stream=0.sdp ?real_stream I get the video but no audio as seen in the left pic If I use VLC with the same stream parameters I get the right unusable picture but I get the audio. (I did download VLCforvMIX) Yes I know I could use the video from one and the audio from the other but I am trying for a single input solution. Any thoughts much appreciated?
whats about RTSP over UDP?
Hi Xaver
Nope, didn't work, I tried all the other settings and only those two worked at all.
I am assuming with the RTMP stream I am going to have to specify the audio stream separate to the video stream somehow?
when you open the RTSP direct with VLC Player, everything is working? which Codecs are shown in VLC
 IMG_6665.jpg (351kb) downloaded 2 time(s).If I just use the normal VLS I only need to select the URL 192.168.1.11:554 and it then asks for username and password and after a few seconds it all opens, video and audio. The pic shows the settings.
have you tried rtsp://user:pw@192.168.1.11:554/channel=1&stream=0.sdp rtsp://user:pw@192.168.1.11:554/&channel=1&stream=0.sdp or some similar combinations in vMix?
I will try that and get back to you, many thanks.
I tried both of those and got a 401 and a black screen, thanks anyway. I am still researching RTSP.
