NTSC
#1 Posted : Sunday, May 3, 2020 10:30:16 AM(UTC)
NTSC
Is there a way to set up a trigger to perform an action at a specific time as a video played back during air?
I don't want to perform the action at the end of playback but rather at a specific time. .
#2 Posted : Sunday, May 3, 2020 10:48:00 AM(UTC)
Scripting will be in order
see "scripting for dummies post" , there is a script in there to do just that
NTSC
#3 Posted : Sunday, May 3, 2020 12:27:54 PM(UTC)
NTSC
Thx. I read that and the scripting documentation.
It did not pop to me how it works or what variables I need to edit. I'll keep looking.
#4 Posted : Sunday, May 3, 2020 7:31:59 PM(UTC)
all you need to do is change the API.Function "action" ( any that is available also as shortcut) to whatever you want it to do when then
https://forums.vmix.com/...ng-for-Dummies#post71985
stigaard on 5/4/2020(UTC)
richardgatarski
#5 Posted : Sunday, May 3, 2020 7:45:49 PM(UTC)
richardgatarski
Depending on how many triggers you have for the video, you can delay the trigger to the point in the video to when you want it to kick in.
NTSC
#6 Posted : Monday, May 4, 2020 12:38:09 PM(UTC)
NTSC
Thanks. I just have one action. I want cut away from the video at :45 in.
NTSC
#7 Posted : Monday, May 4, 2020 12:51:25 PM(UTC)
NTSC
Just took the sample that Doggy wrote, and edited it so that with 40 seconds left in my video, it does a fly rotate to the preview.
It did not work :(
' Checking time left of active input
' and do some stuff at certain time remaining
dim position as string = ""
dim duration as string = ""
dim activeinput as string = ""
dim Timeleft as double = 0
dim triggertime as integer = 40000 '40 seconds before end
dim triggerduration as integer = 500 'fade duration, could be different than trigger
do while true
dim xml as string = API.XML()
x.loadxml(xml)
activeinput = (x.SelectSingleNode("//active").InnerText)
duration = (x.SelectSingleNode("//input[@number='"& activeinput &"']/@duration").Value)
position = (x.SelectSingleNode("//input[@number='"& activeinput &"']/@position").Value)
Timeleft= Double.Parse(duration)-Double.Parse(position)
if Timeleft < triggertime
API.Function("FlyRotate",Input:=activeinput.tostring(),Value:="0," & triggerduration.tostring())
' do whatever one wants to do
end if
sleep(500)
Loop
#8 Posted : Monday, May 4, 2020 5:41:53 PM(UTC)
Code:
  API.Function("FlyRotate",Input:="name or nr input to fly in")
  sleep(1000)
end if
#9 Posted : Monday, May 4, 2020 6:07:43 PM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
Input.Preview.Function("FlyRotate") is what you need.
stigaard on 5/4/2020(UTC), doggy on 5/4/2020(UTC)
#10 Posted : Monday, May 4, 2020 6:11:19 PM(UTC)
Thanks, ignore my mail about API.Function("FlyRotate",Input:="Preview") not working ;-)
NTSC
#11 Posted: : Tuesday, May 5, 2020 1:05:01 PM(UTC)
NTSC
Thanks! That worked perfectly - but now it keeps looping - I see at the end a LOOP command. How can I get a full stop in there?
#12 Posted : Thursday, May 7, 2020 4:22:51 AM(UTC)
Exit
NTSC
#13 Posted : Thursday, May 7, 2020 7:30:17 AM(UTC)
NTSC
Thanks doggy
KnKproductions
#14 Posted : Tuesday, May 12, 2020 1:37:45 PM(UTC)
KnKproductions
Change the mark-out point on the video, set a trigger to do something at the completion of the video. No real need to mess with scripting.
NTSC
#15 Posted : Tuesday, May 12, 2020 1:39:22 PM(UTC)
NTSC
Right...except I want the music from the video to be playing under my production after I cut away from it.
KnKproductions
#16 Posted : Tuesday, May 12, 2020 1:51:48 PM(UTC)
KnKproductions
ah.. two actions then :)
I do the same thing on an intro video, but instead of playing the embedded audio I load it as an audio file in vmix and marry the two with a trigger. When the video goes to output it plays, and simultaneously triggers the accompanying audio file (music). Once the video is done, it's triggered to fade to another input and the audio file keeps playing separately with no interruptions. Then I fade out the music on the midi controller.
example:
That way of doing it gives a lot of control on the fly
NTSC
#17 Posted : Tuesday, May 12, 2020 2:17:39 PM(UTC)
NTSC
Yea, I considered trying that. You've inspired me to give it a try.
Thanks.
KnKproductions
#18 Posted : Wednesday, May 13, 2020 12:25:34 AM(UTC)
KnKproductions
Thanks.
I think you'll find it's quite easy, maybe the only hard part is getting the audio file by itself. I was 'lucky' that the intro music was a normal song that was available on amazon music.
Might be helpful to include some reset triggers so that when the video transitions out, it automatically resets to the mark-in position. Same with the audio file... fading it out and letting it finish, then it does its own trigger to reset upon completion. This way, if you play the video/audio sequence again later on, it will be ready. After I had forgotten to restart the audio after a test run, I decided to add that trigger. Nice little failsafe.
If you need any help separating the audio I can do it in a few minutes, just send a download link to the video.
NTSC
#19 Posted : Wednesday, May 13, 2020 1:42:32 AM(UTC)
NTSC
Thanks for the offer. I should be ok! Thank you so much for your help.
Guest (4)
