Trigger at a time in a video playback
Joined: 5/3/2020(UTC) Views messages in topic : 35  Was thanked: 1 time(s) in 1 post(s)
Is there a way to set up a trigger to perform an action at a specific time as a video played back during air?
I don't want to perform the action at the end of playback but rather at a specific time. .
Joined: 12/27/2012(UTC) Posts: 5,475  Location: Belgium Thanks: 313 times Was thanked: 1013 time(s) in 832 post(s)
Scripting will be in order
see "scripting for dummies post" , there is a script in there to do just that
Originally Posted by: doggy  Scripting will be in order
see "scripting for dummies post" , there is a script in there to do just that Thx. I read that and the scripting documentation. It did not pop to me how it works or what variables I need to edit. I'll keep looking.
all you need to do is change the API.Function "action" ( any that is available also as shortcut) to whatever you want it to do when then https://forums.vmix.com/...ng-for-Dummies#post71985
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
Depending on how many triggers you have for the video, you can delay the trigger to the point in the video to when you want it to kick in.
Thanks. I just have one action. I want cut away from the video at :45 in.
Just took the sample that Doggy wrote, and edited it so that with 40 seconds left in my video, it does a fly rotate to the preview.
It did not work :(
' Checking time left of active input ' and do some stuff at certain time remaining
dim position as string = "" dim duration as string = "" dim activeinput as string = "" dim Timeleft as double = 0 dim triggertime as integer = 40000 '40 seconds before end dim triggerduration as integer = 500 'fade duration, could be different than trigger
do while true
dim xml as string = API.XML() dim x as new system.xml.xmldocument x.loadxml(xml)
activeinput = (x.SelectSingleNode("//active").InnerText) duration = (x.SelectSingleNode("//input[@number='"& activeinput &"']/@duration").Value) position = (x.SelectSingleNode("//input[@number='"& activeinput &"']/@position").Value)
Timeleft= Double.Parse(duration)-Double.Parse(position)
if Timeleft < triggertime
API.Function("FlyRotate",Input:=activeinput.tostring(),Value:="0," & triggerduration.tostring()) ' do whatever one wants to do
end if
sleep(500) Loop ******************************
Code:if Timeleft < triggertime
API.Function("FlyRotate",Input:="name or nr input to fly in")
sleep(1000)
end if
Joined: 1/13/2010(UTC) Posts: 5,297  Location: Gold Coast, Australia Was thanked: 4674 time(s) in 1609 post(s)
Input.Preview.Function("FlyRotate") is what you need.
Originally Posted by: admin  Input.Preview.Function("FlyRotate") is what you need. Thanks, ignore my mail about API.Function("FlyRotate",Input:="Preview") not working ;-)
Thanks! That worked perfectly - but now it keeps looping - I see at the end a LOOP command. How can I get a full stop in there?
Originally Posted by: NTSC  Thanks! That worked perfectly - but now it keeps looping - I see at the end a LOOP command. How can I get a full stop in there? Exit
Joined: 4/6/2019(UTC) Posts: 95  Location: Florida Thanks: 10 times Was thanked: 13 time(s) in 11 post(s)
Change the mark-out point on the video, set a trigger to do something at the completion of the video. No real need to mess with scripting.
Right...except I want the music from the video to be playing under my production after I cut away from it.
Originally Posted by: NTSC  Right...except I want the music from the video to be playing under my production after I cut away from it. ah.. two actions then :) I do the same thing on an intro video, but instead of playing the embedded audio I load it as an audio file in vmix and marry the two with a trigger. When the video goes to output it plays, and simultaneously triggers the accompanying audio file (music). Once the video is done, it's triggered to fade to another input and the audio file keeps playing separately with no interruptions. Then I fade out the music on the midi controller. example: That way of doing it gives a lot of control on the fly
Yea, I considered trying that. You've inspired me to give it a try.
Thanks.
Originally Posted by: NTSC  Yea, I considered trying that. You've inspired me to give it a try.
Thanks.
I think you'll find it's quite easy, maybe the only hard part is getting the audio file by itself. I was 'lucky' that the intro music was a normal song that was available on amazon music. Might be helpful to include some reset triggers so that when the video transitions out, it automatically resets to the mark-in position. Same with the audio file... fading it out and letting it finish, then it does its own trigger to reset upon completion. This way, if you play the video/audio sequence again later on, it will be ready. After I had forgotten to restart the audio after a test run, I decided to add that trigger. Nice little failsafe. If you need any help separating the audio I can do it in a few minutes, just send a download link to the video.
Thanks for the offer. I should be ok! Thank you so much for your help.
