Kupono
#1 Posted : Tuesday, August 16, 2011 4:52:47 PM(UTC)
Kupono
Hello vMix community.
I just found vMix and so far love it!
My set-up:
i7 2600 Win 7 desktop
8gb ram
2x allegro firewire (fw) cards
vMix v2011 (trial)
FLME 3.2
I'm setting up for a 2-source live edit, live webcast -- 1x DV camera via firewire into 1st allegro fw card; 1x VGA out from presentation laptop (thru AV Tool scan converter, out via s-video thru ADVC-55 converter, out via fw into 2nd allegro fw card)
vMix recognizes both sources perfect.
vMix shows up as video device in FLME, and preview (in & out) displays proper when audio is un-checked. vMix does not show up as audio device -- only 'Microsoft DV camera and VCR' & 'AV/C Tape Recorder/PLayer' are available.
Only audio in the mix is what's coming through DV camera.
How do I send vMix audio to FLME?
I have been able to successfully encode using FLME in video only mode -- switching is beautiful and smooth. I am encoding in 640x480 700kbps h264 29.97fps. Did 50 switches before ending test and it worked perfect...just no audio.
Thanks in advance for help.
#2 Posted : Tuesday, August 16, 2011 5:56:34 PM(UTC)
Please see if the following help item helps:
http://www.vmix.com.au/h...files/LiveStreaming.html
If you do not have a "Stereo Mix" or "What U Hear" audio source on your computer, you can enable it through the following:
http://forums.vmix.com.a...t.aspx?g=posts&t=170
Martin Sinclair
Kupono
#3 Posted : Tuesday, August 16, 2011 6:25:59 PM(UTC)
Kupono
Thanks for your prompt response.
I found both links prior to posting this and followed instructions with no success.
There are no 'what u hear' or 'wave' option in FMLE.
So I followed other post's advice and clicked 'show disabled devices'. Then, Stereo Mix shows but can't click it to open. I'm trying this again from step 1...perhaps I opened FMLE too soon.
On a separate note, I noticed that switching between both video inputs also switches audio source. Is there a way to select one audio source without it fading between switches and manually having to re-select audio from video camera source?
Thanks for you support. This is a great piece of software.
Might this have to do with windows update, or version 3.2 of FMLE?
#4 Posted : Tuesday, August 16, 2011 11:26:16 PM(UTC)
Once the Stereo Mix option is visible in the Recording section of the Sound control panel right click it and select Enable.
Then reopen FMLE and it will appear as a sound recording option.
To disable automatic audio switching, click the i button for the input and untick "Automatically Mix Audio"
Martin Sinclair
#5 Posted : Wednesday, August 17, 2011 12:34:05 AM(UTC)
I have updated the Help with the following guide:
http://www.vmix.com.au/h...iles/RecordingAudio.html
Kupono
#6 Posted : Wednesday, August 17, 2011 3:32:56 AM(UTC)
Kupono
Thanks for walking me through this.
I better understand how audio is handled now.
Incredible software, excellent support.
