Limit Web Controller window access
Joined: 10/16/2014(UTC) Posts: 32 Location: San Jose, CA
I am on v23. I have set up username/password on Web Controller. Is there a way to allow only access to Shortcuts and nothing else? I would like to remote Powerpoint presenters to only be able to advance or reverse slides. I do not want them to be able to access controller, tally, and title pages. Thanks!
Joined: 4/30/2020(UTC) Posts: 7  Location: istanbul Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Joined: 12/4/2018(UTC) Posts: 52  Location: Brussels Thanks: 3 times Was thanked: 11 time(s) in 11 post(s)
If you aren't using that functionality you can simply disable those pages, if that helps
Originally Posted by: epicenter800  I am on v23. I have set up username/password on Web Controller. Is there a way to allow only access to Shortcuts and nothing else? I would like to remote Powerpoint presenters to only be able to advance or reverse slides. I do not want them to be able to access controller, tally, and title pages. Thanks! Just make the shortcuts you want to be seen visible in the web-controller. https://www.vmix.com/hel...dex.htm?AddShortcut.htmlThen make the shortcut page visible without a password.
Joined: 4/23/2017(UTC) Posts: 1,496  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Alternatively the remote guest can present locally but present online with powerpoint. Microsoft will create the presentation online and provide a link. You can embed the presentation as a webpage in vMix. This way all the features in powerpoint will work (Animation, custom Font), the presenters don't have to send presentation around and have control over it.
