epicenter800
#1 Posted : Friday, April 24, 2020 2:31:10 AM(UTC)
epicenter800
I am on v23. I have set up username/password on Web Controller. Is there a way to allow only access to Shortcuts and nothing else? I would like to remote Powerpoint presenters to only be able to advance or reverse slides. I do not want them to be able to access controller, tally, and title pages.
Thanks!
Kemal
#2 Posted : Friday, May 8, 2020 3:18:07 AM(UTC)
Kemal
Turkey
+1
TobinT
#3 Posted : Friday, May 8, 2020 7:28:19 AM(UTC)
TobinT
Was thanked: 11 time(s) in 11 post(s)
If you aren't using that functionality you can simply disable those pages, if that helps
ask
#4 Posted : Friday, May 8, 2020 9:01:32 AM(UTC)
ask
Thanks!
Just make the shortcuts you want to be seen visible in the web-controller. https://www.vmix.com/hel...dex.htm?AddShortcut.html
Then make the shortcut page visible without a password.
mavik
#5 Posted : Friday, May 8, 2020 10:31:38 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
Alternatively the remote guest can present locally but present online with powerpoint. Microsoft will create the presentation online and provide a link. You can embed the presentation as a webpage in vMix. This way all the features in powerpoint will work (Animation, custom Font), the presenters don't have to send presentation around and have control over it.
