CyberTiger
#1 Posted : Tuesday, May 5, 2020 4:31:58 AM(UTC)
CyberTiger
So I setup a cloud server as my home connection is not fast enough and I have an urgent event coming up. I may have a plan B but was looking at this as an option. I can get the video on the screen for other assets and sound no issues. When I setup the VCall I can connect and I get audio though I get NO video anywhere for the caller...Any insights into a setting or what may not be working?
Thank you in advance
Follo
#2 Posted : Wednesday, May 6, 2020 7:53:11 PM(UTC)
Follo
Germany
Was thanked: 17 time(s) in 10 post(s)
have you tried to disable the peer-to-peer connection in the vmix call settings?
You can also try to forward ports in your Firewall:
https://www.vmix.com/kno...ll-firewall-requirements
Hope it helps.
CyberTiger
#3 Posted : Thursday, May 7, 2020 6:10:11 AM(UTC)
CyberTiger
Thanks for the response...I removed the firewall by stopping all services. Still same result. I tried with and without the peer-to-peer no difference. The VMix studio I can stream other video sources fine. I can get audio from the call just no video? Not sure how else to troubleshoot...
