Joined: 5/5/2020(UTC) Posts: 3  Location: Riga Thanks: 1 times
Hi guys! Im a big vMix fan! Thanks for this software, and for improving it time by time!!!
I have might be a weird question, but google gave me 0 results. I have 3 Mixes in my production for one project. Is there any possibility to send a "next/previous input" to preview only for example to Mix2? With a shortcut ofc!
Thanks in advance!
Joined: 4/23/2017(UTC) Posts: 1,433  Location: Germany Thanks: 3 times Was thanked: 191 time(s) in 171 post(s)
If you use the mini mixers yes. And they can be targeted with shortcuts. Just use the mix dropdown for it.
Originally Posted by: mavik  If you use the mini mixers yes. And they can be targeted with shortcuts. Just use the mix dropdown for it. There is a PreviewInputNext or PreviewInputPrevious shortcuts, but they are only for Mix1 (Output), not for Mix2/3/4 etc.
Joined: 3/7/2012(UTC) Posts: 2,683  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ Vladis
You can only send to Mix2 Preview a specific Input with the "PreviewInput" Shortcut. The variable you could use would be "Hover" but will require you to use the mouse + shortcut.
Joined: 12/27/2012(UTC) Posts: 5,486  Location: Belgium Thanks: 314 times Was thanked: 1019 time(s) in 837 post(s)
Lets see (thinking out loud)
There are shortcuts to populate the Preview and Output of a Mix.
Now if your intention is to uses previous/next based on your current inputs you could call a script (with a shortcut) that checks the current input's number and adds/subtract one to then execute those mentioned above functions
That's one possibility
