Vladis
#1 Posted : Tuesday, May 5, 2020 8:37:25 PM(UTC)
Vladis
Latvia
Hi guys! Im a big vMix fan! Thanks for this software, and for improving it time by time!!!
I have might be a weird question, but google gave me 0 results. I have 3 Mixes in my production for one project. Is there any possibility to send a "next/previous input" to preview only for example to Mix2? With a shortcut ofc!
Thanks in advance!
mavik
#2 Posted : Tuesday, May 5, 2020 11:58:34 PM(UTC)
mavik
If you use the mini mixers yes. And they can be targeted with shortcuts. Just use the mix dropdown for it.
Vladis
#3 Posted : Wednesday, May 6, 2020 4:17:01 PM(UTC)
Vladis
Latvia
There is a PreviewInputNext or PreviewInputPrevious shortcuts, but they are only for Mix1 (Output), not for Mix2/3/4 etc.
#4 Posted : Wednesday, May 6, 2020 9:35:27 PM(UTC)
@ Vladis
You can only send to Mix2 Preview a specific Input with the "PreviewInput" Shortcut.
The variable you could use would be "Hover" but will require you to use the mouse + shortcut.
#5 Posted : Wednesday, May 6, 2020 10:04:02 PM(UTC)
Lets see (thinking out loud)
There are shortcuts to populate the Preview and Output of a Mix.
Now if your intention is to uses previous/next based on your current inputs you could call a script (with a shortcut) that checks the current input's number and adds/subtract one to then execute those mentioned above functions
That's one possibility
