Hear audio busses in headphones
Joined: 3/29/2020(UTC) Posts: 103  Thanks: 20 times Was thanked: 2 time(s) in 2 post(s)
Is there any way I can hear the audio buses in my headphone output without the main mix. I just want to hear the buses. I know I can solo each bus but I want to hear all my buses at the same time with out putting them into the main mix? As an alternative, I want to hear the audio of each of my vmix callers through my headphones without them being in the main mix as two vmix callers are producers.
Thanks.
Joined: 10/13/2012(UTC) Posts: 1,157  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
In the External Settings enable NDI on the Audio outputs. This will allow all busses to be seen as NDI sources. Bring them into a seperate PC/Laptop for monitoring, or bring them into vMix as NDI inputs and group them together on one bus. Set the output of that bus to your headphones.
 1 user thanked ask for this useful post.
Originally Posted by: ask  In the External Settings enable NDI on the Audio outputs. This will allow all busses to be seen as NDI sources. Bring them into a seperate PC/Laptop for monitoring, or bring them into vMix as NDI inputs and group them together on one bus. Set the output of that bus to your headphones. Thanks, actually did a similar thing by using an external SDI output and sending the M-G busses to that, then monitored the channels (buses) I needed. Not ideal, but it worked. I do like the NDI idea though... Hadn't thought of that.
