Tone13
#1 Posted : Friday, May 1, 2020 4:42:48 PM(UTC)
Tone13
Is there any way I can hear the audio buses in my headphone output without the main mix. I just want to hear the buses. I know I can solo each bus but I want to hear all my buses at the same time with out putting them into the main mix?
As an alternative, I want to hear the audio of each of my vmix callers through my headphones without them being in the main mix as two vmix callers are producers.
Thanks.
ask
#2 Posted : Saturday, May 2, 2020 10:01:16 AM(UTC)
ask
Was thanked: 199 time(s) in 181 post(s)
In the External Settings enable NDI on the Audio outputs. This will allow all busses to be seen as NDI sources. Bring them into a seperate PC/Laptop for monitoring, or bring them into vMix as NDI inputs and group them together on one bus. Set the output of that bus to your headphones.
stigaard on 5/2/2020(UTC)
Tone13
#3 Posted : Saturday, May 2, 2020 9:23:28 PM(UTC)
Tone13
Thanks, actually did a similar thing by using an external SDI output and sending the M-G busses to that, then monitored the channels (buses) I needed. Not ideal, but it worked. I do like the NDI idea though... Hadn't thought of that.
