Solved ! Vmix 11.0.0.63 in Win 8.1 pro MBP BootCamp
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Hello
We are running vmix 11.0.0.63 trial in Bootcamp Mac Book Pro (late 2013) with windows 8.1 Pro. We consider to instal Vmix in new mac pro and this is testing setup. Working fine with thunderbolt capture cards and playback and videodelay, but...
When we add input to be "Title" or "Virtual Set" Vmix resize the Vmix UI window to be smaller in desktop and moves the external output window from second monitor to desktop also. If we try to resize the UI window to full screen again, font sizes will be weird and UI messed up.
Anybody found something similar? .Net Framework Problem? Vmix Installad (or Win 8.1) .Net 3.5 during software installation. 3.5 SP1 is not available for Win 8.1.
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
Can you provide a screenshot so I can better understand what you are describing?
Martin vMix
I just sent an email with screen captures into your info email address. Don't know how to attach here. Can you get them from there?
Setup is:
Mac Book Pro 15" 2,3 GHz Intel Core i7 Memory 16Gt Nividia Geforce GT 750M 2Gt
Windows 8.1 pro BootCamp
Problem occurs also when thunderbolt capture cards are not connected
Thanks,
Could you go to start menu type in dxdiag and press enter. In the main window of dx diag click "save all information" and send us the text file.
Martin vMix
In the control panel -> Appearance and Personalization -> Display change the scaling to 125% or lower.
vMix does not currently supported 150% or higher scaling.
Martin vMix
Problem solved!
Thank You Martin, fast response !
