kk.media
#1 Posted : Thursday, April 30, 2020 6:50:33 AM(UTC)
kk.media
Austria
Dear vMix Users,
i got a question about the vcall and external camera input:
my vcall guest wants to use an external camera via atem mini on his mac.
Does anyone know how he can select the external camera in safari to use the external camera and not the built in?
Maybe an other way can be:
he uses the app manycam on his mac, and he already streamed to facebook with this. But he needs a stream and login data for this.
Can I host a stream out of vmix so he can log in and stream his camera directly to me?
Of course the easiest way would be, he uses vmix as well and we connect to each other, but he is using mac, so using vmix is not possible.
thanks a lot for your ideas!
best, meischi
TobinT
#2 Posted : Thursday, April 30, 2020 7:53:10 AM(UTC)
TobinT
Was thanked: 11 time(s) in 11 post(s)
If his capture device isn't natively picked up by the browser then he'll need to use something that can convert it into a virtual web cam. On mac OBS with the virtual camera plugin will do the job.
kk.media
#3 Posted : Thursday, April 30, 2020 4:33:41 PM(UTC)
kk.media
Austria
I was thinking about OBS Studio as well - but was thinking, that there should be an easier way for this.
We found kind of a solution - we used safari for the first try and he wasnt able to select his external camera as an input, but with chrome it works fine.
Seems like a safari issue.
DaveT
#4 Posted : Tuesday, May 19, 2020 9:27:27 AM(UTC)
DaveT
Needs a UVC compliant HDMI/SDI to USB device so browser will see (the device) like a webcam.
Vince Beck
#5 Posted : Wednesday, May 20, 2020 5:15:11 AM(UTC)
Vince Beck
In Chrome, click the camera icon in the browser bar. Settings will be greyed out. You need to click on Manage then change the mic/camera in the Chrome settings.
DaveT
#6 Posted : Wednesday, May 20, 2020 9:27:04 AM(UTC)
DaveT
chrome://settings/content/camera
chrome://settings/content/microphone
If you think you may find yourself going to these settings regularly, you can create a bookmark!
beta.vixcall.com has a settings button to adjust your camera/mic so it'll make that part easier in the end.
DT
