Feature Requests
Add an audio bus to the Main (mix-) audio a vmix call guest receives.
Joined: 3/29/2020(UTC) Posts: 104  Thanks: 20 times Was thanked: 2 time(s) in 2 post(s)
I'd like to be able to add one or multiple audio busses to the mix- audio that a vmix caller receives. So, if I had a producer on another vmix call, I could put them on Bus C and send my vmix caller the Main audio (like they currently get in mix- form) and the producers mic mixed into that feed. Cheers.
Originally Posted by: IceStream  Yes I have, but I want to give each of my vMix callers the main mix (without their own mic, which vmix handles automatically) plus the audio busses that have the other callers Mics selected so they/we can all talk to each other while we are on a long VT.
Joined: 12/4/2018(UTC) Posts: 52  Location: Brussels Thanks: 3 times Was thanked: 11 time(s) in 11 post(s)
Try the following (I believe this will do what you want) Use a bus for example bus A as your program mix instead of the main M bus. So reconfigure records, outputs etc, accordingly. Keep return routing to any mix callers from the M bus. This way you can route your PGM on bus A to the callers (on bus M) and add any additional sources (Producer mic for example) to the main mix (bus M) without it going out to PGM (still on bus A). Inputs -> bus A bus A -> Records bus A -> Stream bus A -> outputs bus A -> Bus M Bus M -> Vmix call return Producer mic -> Bus M Hope that makes some form of sense.
Feature Requests
