Tone13
#1 Posted : Tuesday, April 28, 2020 10:58:22 AM(UTC)
Tone13
I'd like to be able to add one or multiple audio busses to the mix- audio that a vmix caller receives.
So, if I had a producer on another vmix call, I could put them on Bus C and send my vmix caller the Main audio (like they currently get in mix- form) and the producers mic mixed into that feed.
Cheers.
#2 Posted : Tuesday, April 28, 2020 10:00:10 PM(UTC)
@ Tone13
Have you enabled Buses C to G is vMix Audio Output Settings?
Once enabled, all those "extra" busses will be available as a source for vMix Callers.
https://www.vmix.com/help23/AudioOutputs.html
Tone13
#3 Posted : Wednesday, April 29, 2020 9:09:08 AM(UTC)
Tone13
Originally Posted by: IceStream Go to Quoted Post
@ Tone13
Yes I have, but I want to give each of my vMix callers the main mix (without their own mic, which vmix handles automatically) plus the audio busses that have the other callers Mics selected so they/we can all talk to each other while we are on a long VT.
TobinT
#4 Posted : Wednesday, April 29, 2020 6:16:48 PM(UTC)
TobinT
Was thanked: 11 time(s) in 11 post(s)
Try the following (I believe this will do what you want)
Use a bus for example bus A as your program mix instead of the main M bus. So reconfigure records, outputs etc, accordingly.
Keep return routing to any mix callers from the M bus.
This way you can route your PGM on bus A to the callers (on bus M) and add any additional sources (Producer mic for example) to the main mix (bus M) without it going out to PGM (still on bus A).
Inputs -> bus A
bus A -> Records
bus A -> Stream
bus A -> outputs
bus A -> Bus M
Bus M -> Vmix call return
Producer mic -> Bus M
Hope that makes some form of sense.
