export button virtual set: does it work?
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
hi all, tried saving a virtual set with export button, but al it does is ask for a directory to save, but nothing happens.
did I miss something? cheers Stefan
ps help has no mention of that button...
@ h2video.nl
What "Export" button are you referring to?
in the add inout virtual set under visible layer you find EXPORT.
when you click it it it asks for a directory. then nothing.
the export is handy to save a virtual set so you do not need to do all the setting ove and over ( look in the manual or just add input and check ... ) stefan
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
When you click on export, all the components of virtualset (config.xml included) are saved in the directory of your choice).
i do not see these! do you ? it just asks for a directory but nothing is saved. the how would you load it after it is saved?
1) click on export 2) a window is opened 3) click on the folder in the left side where you want to save 4) be sure that the folder is selected (can you see the name of the folder in the space below in the window?) 5) click on "select folder"
It's all. Try selecting foe example desktop and check it.
I have the same issue, except that in selecting the virtual set that I saved, it does not show the file, but the folder....when I select the folder, then I click OK on the window to load the saved set, it loads the virtual set layout only....none of the images etc are loaded, but the settings are there as in the layout I saved....I was hoping for the images and everything to be loaded as well, but that does not happen...I have to go and reload all of them
Originally Posted by: Joeboe  I have the same issue, except that in selecting the virtual set that I saved, it does not show the file, but the folder....when I select the folder, then I click OK on the window to load the saved set, it loads the virtual set layout only....none of the images etc are loaded, but the settings are there as in the layout I saved....I was hoping for the images and everything to be loaded as well, but that does not happen...I have to go and reload all of them
Same thing happen to me. Can someone confirm what the export button actually does because for me it does not save any of image that I put in the layer. It just save a config file, a thumbnail of my virtual set and the original template(Blank10) used.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: DFNB  Originally Posted by: Joeboe  I have the same issue, except that in selecting the virtual set that I saved, it does not show the file, but the folder....when I select the folder, then I click OK on the window to load the saved set, it loads the virtual set layout only....none of the images etc are loaded, but the settings are there as in the layout I saved....I was hoping for the images and everything to be loaded as well, but that does not happen...I have to go and reload all of them
Same thing happen to me. Can someone confirm what the export button actually does because for me it does not save any of image that I put in the layer. It just save a config file, a thumbnail of my virtual set and the original template(Blank10) used. https://forums.vmix.com/...ve-virtual-set#post94686
