santtlorenzo
#1 Posted : Tuesday, April 28, 2020 2:26:33 AM(UTC)
santtlorenzo
Spain
Hello, I have a colored background with a multiview of 9 signals and I want to title each one of them. How can I configure the text labeling? I don't know how to generate a different text for each title from the title editor. Thanks
#2 Posted : Tuesday, April 28, 2020 2:56:32 AM(UTC)
santtlorenzo
#3 Posted : Tuesday, April 28, 2020 3:22:20 AM(UTC)
santtlorenzo
Spain
Thanks. I can do insert title perfectly in the program signal. But what I want to do is label two or more signals at the same time either with PIP or in multiview. For example, have 6 simultaneous connections in multiview and a title for each viewer that identifies your name, john, arthur, Jane, etc ... Thank you very much
#4 Posted : Tuesday, April 28, 2020 7:46:01 AM(UTC)
I believe by signals you are meaning inputs.
IMO there are a few options :
Have each input a layer with a title (is also multiview)
have one big title that matches the layout of you multivies with text fields in the proper locations
santtlorenzo
#5 Posted : Tuesday, April 28, 2020 5:03:37 PM(UTC)
santtlorenzo
Spain
Thank you very much, it is not possible to use a trigger?
if I have a multiview of 9 inputs, could I configure the trigger so that when I am multiview (9) in the program?,
could I trigger the different titles with design to each one?
Thank you very much for your explanation and help.
Great consultation forum.
