Multiview and multiples text
Hello, I have a colored background with a multiview of 9 signals and I want to title each one of them. How can I configure the text labeling? I don't know how to generate a different text for each title from the title editor. Thanks
Originally Posted by: santtlorenzo  I don't know how to generate a different text for each title from the title editor. Thanks
Thanks. I can do insert title perfectly in the program signal. But what I want to do is label two or more signals at the same time either with PIP or in multiview. For example, have 6 simultaneous connections in multiview and a title for each viewer that identifies your name, john, arthur, Jane, etc ... Thank you very much
I believe by signals you are meaning inputs.
IMO there are a few options : Have each input a layer with a title (is also multiview) have one big title that matches the layout of you multivies with text fields in the proper locations
Thank you very much, it is not possible to use a trigger? if I have a multiview of 9 inputs, could I configure the trigger so that when I am multiview (9) in the program?, could I trigger the different titles with design to each one? Thank you very much for your explanation and help. Great consultation forum.
