znarkus
#1 Posted : Sunday, April 26, 2020 4:20:11 AM(UTC)
znarkus
Sweden
Hi!
I'm trying to create a ticker that reads from an JSON api endpoint, that looks somethings like this:
Text 1 • Text 2 • Text 2 is very loooooooooong • Etc ..
This is read from an api that looks similar to this:
{ "body": "Text 1" },
{ "body": "Text 2" },
{ "body": "Text 2 is very loooooooooong" },
{ "body": "Etc .." }
I almost created it with the GT editor, with "Add" ticker instead of "Replace".
But is there a way to add a separator between the items?
#2 Posted : Sunday, April 26, 2020 4:48:36 AM(UTC)
just add a seperator character to your format setting of the datasource in your title(ticker)
znarkus
#3 Posted : Sunday, April 26, 2020 4:50:36 AM(UTC)
znarkus
Sweden
That would add it to the last item as well, right? Like this
Text 1 • Text 2 •
#4 Posted : Sunday, April 26, 2020 4:53:32 AM(UTC)
yes as in how would it know its the last one anyway unless you drive the data with and external app or a script
znarkus
#5 Posted : Sunday, April 26, 2020 5:11:04 AM(UTC)
znarkus
Sweden
I'm not entirely sure what you mean. The list definitely is finite.
#6 Posted : Sunday, April 26, 2020 5:27:04 AM(UTC)
What i say is , unless you manipulate your data sending differently to the title ( external app or script) you have basically an infinite list (no indication of end of list to make a decision) and are stuck to the basic addition of a separator or other text before/after each item
with scripts or apps your data manipulation before displaying is infinite :-)
