GT
Ticker items separator
Hi!
I'm trying to create a ticker that reads from an JSON api endpoint, that looks somethings like this:
Text 1 • Text 2 • Text 2 is very loooooooooong • Etc ..
This is read from an api that looks similar to this:
[ { "body": "Text 1" }, { "body": "Text 2" }, { "body": "Text 2 is very loooooooooong" }, { "body": "Etc .." } ]
I almost created it with the GT editor, with "Add" ticker instead of "Replace". But is there a way to add a separator between the items?
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
just add a seperator character to your format setting of the datasource in your title(ticker)
Originally Posted by: doggy  just add a seperator character to your format setting of the datasource in your title(ticker)
That would add it to the last item as well, right? Like this Text 1 • Text 2 •
yes as in how would it know its the last one anyway unless you drive the data with and external app or a script
Originally Posted by: doggy  yes as in how would it know its the last one anyway unless you drive the data with and external app or a script
I'm not entirely sure what you mean. The list definitely is finite.
What i say is , unless you manipulate your data sending differently to the title ( external app or script) you have basically an infinite list (no indication of end of list to make a decision) and are stuck to the basic addition of a separator or other text before/after each item with scripts or apps your data manipulation before displaying is infinite :-)
GT
