tcconway
#1 Posted : Saturday, April 25, 2020 11:53:21 AM(UTC)
tcconway
I just started sending a program feed/output via a Blackmagic Quad 2 card.
When I hit the External button, I can see the video/audio coming into my external video recorder. All looks great.
THEN...60 minutes later, the audio cuts out. The meters within vMix show it is sending External audio. Even my Master and BusA are showing meters. But the external video recorder loses audio. I'm also sending NDI out, and that does not drop audio. During the 60 minutes, I don't touch the PC. Screensaver and power save is off.
I have swapped SDI cables and swapped external devices. The audio still cuts out after 60 minutes. I have to click External to turn off the output, wait a beat and click the External button for it to come back (for another 60 minutes)
Any suggestions?
tcconway
#2 Posted : Sunday, April 26, 2020 12:30:16 AM(UTC)
tcconway
Update: I'm testing it all day to figure out what's going on. It just cut out after 23 minutes, instead of the 60 minutes before.
GPU/CPU are both under 11%. Total averages 6%
Thanks!
ask
#3 Posted : Sunday, April 26, 2020 8:06:26 AM(UTC)
ask
Sounds like an issue with your BM card. Try connecting your recorder directly to your graphics card via HDMI.
GHdrumstick
#4 Posted : Friday, November 27, 2020 1:29:29 PM(UTC)
GHdrumstick
I had the same issue as tcconway on location for a multi-camera livestream. Running vMix 23.0.0.66 on i7 6-core | 32 GB RAM | Quadro P2200 graphics BMD Quad 2 - 8 port i/o card.
I experienced audio cut-out repeatedly on the external output after about 90 seconds. Project was set up for 1080P 29.97. wasn't streaming or recording when this happened. CPU at 10%.
Back at my studio I could not replicate the problem. The only difference during my studio test is that I did not have the three camera inputs engaged. I wonder if the capture card glitched because of the 3 camera inputs? Anyway, I thought I should post this for reference sake since at least one other person had the same issue.
Danny.H706
#5 Posted : Wednesday, March 1, 2023 1:49:13 AM(UTC)
Danny.H706
Hey I have been doing this for about 2 years now. we have 11 Active vmix machines, some with decklink duo and some decklink quad cards. the issue seems to vary across all my builds. 5 of the 11 are the SAME exact builds. RTX 3070, AMD Ryzen 7 5800X, 16 gb ram AND 1 tb m.2 dRIVES.
After lots of testing, 3 out of 5 of my identical machines didn't drop audio after outputting on external for 1 week. 1 machine drops roughly at the 10 hour mark and another one dropped after about 55 minutes (sometimes More). I tested outputting on OBS via the Decklink quad cards from these same machines and Audio did not drop after a week of running. My next test would be to try a different SDI capture card like AJA Corvid or something. Anybody have any new ideas about this?
sinc747
#6 Posted : Wednesday, March 1, 2023 1:11:05 PM(UTC)
sinc747
Sounds like a bug. Report it to vMix HQ.
Best wishes.
- Tom
Salvatore
#7 Posted : Wednesday, March 1, 2023 4:36:09 PM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
We have nearly the same issue. We have to start external output twice or even three times, because otherwise the sound is disturbed.
Check also this post:
https://forums.vmix.com/...fline-after-vMIX-restart
cchhita
#8 Posted : Monday, April 3, 2023 11:49:25 PM(UTC)
cchhita
Same issue here.
Decklink card with VMIX fails, but with OBS there are no issues, even if running over multiple days.
We were asked to do a test using VMIX with a clean profile, and it still the same issue.
Is anyone else having the same issue where the audio just completely dies when sending over the Decklink cards? All is fine going out via NDI, Dante etc but fails over SDI on the Decklink, and Only in VMIX, not OBS.
dswerd
#9 Posted : Saturday, May 13, 2023 2:36:13 PM(UTC)
dswerd
Yep, having the same issue here on two separate machines. Vmix is showing levels on the external output in the mixer, but after a variable amount of time (sometimes 30 minutes, sometimes after a few hours) the audio will cut out.
karelholubicka
#10 Posted : Wednesday, October 15, 2025 8:17:16 PM(UTC)
karelholubicka
Czech Republic
Well, same issue here. Maybe for years, since I usually use External out for video only.
Audio at SDI output plays for some minutes, than started to have dropouts and finally dies.
When the same output is driven by BMD Media express, no problem.
I updated BMD drivers from 10 to 15.1 - no change. I disabled BMD audio and AV stream - no change.
W10 + vMix 26.0.0.42 (cannot go to 27, license too old). Playing 1080p50.
karelholubicka
#11 Posted : Wednesday, October 22, 2025 9:26:46 PM(UTC)
karelholubicka
Czech Republic
Hi, after extensive testing I have found...
1/ The issue is machine depending, one configuration (W11+4070) is OK and another (W10+AMD580) has audio failing issues always
2/ Both Decklik Duo2 and 4K cards behave similar, so it is not issue of one BMD card
3/ BMD Drivers update does not change anything
4/ It affects only direct vMix output. I run test to drive simultaneously Decklink Duo2#1 from vMix external and Decklik Duo2#2 via the vMix-NDI-NDItoSDI converter and only external out audio dropped
5/ Audio output behaves like - got scrambled first, then fails. When "scrambling", it sounds like output buffer is not filled fully enough, so sound can even have like 0,5s loops. Or just is scratching.
6/ At the "fail" moment, there is also one, sometime two, BLACK frames at the output (recorded via FFMPEG dshow). But video then recovers, while audio not.
7/ Interestingly, when driving TWO external outputs via TWO instances of vMix, they scramble differently, but the FAIL black frame is identical on BOTH (on the dshow recorded files).
8/ Beside the main issue, when there are two instances of vmix, both directed to different BMD card, they still somehow fight each other about audio - one may lock the second's audio SDI external output, and this can be recovered only by ones restart. Veeeery weird. The output statistics shows big audio latency in this case - f.e. "Jitter: V 0 A 0 ms Latency: V 1 A 298280 ms". However, I think this is different issue than Program audio cutting out.
Vmix used for testing had no inputs except audio beep and bars, all audio outputs are off, acceleration off etc...no changes helped to solve this.
As for now, I can use NDI and NDI-to-SDI converted as solution.
Karel
thanks 1 user thanked karelholubicka for this useful post.
jet on 10/22/2025(UTC)
mavik
#12 Posted : Thursday, October 23, 2025 8:42:32 PM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
This seems to be ongoing for longer and also seems to be reproducible. Have you reported the issue to vmix support. They should be able to analyse and help, especially if it's reproducible.
karelholubicka
#13 Posted : Friday, October 24, 2025 7:11:46 AM(UTC)
karelholubicka
Czech Republic
Reported, We'll see.
karelholubicka
#14 Posted : Sunday, October 26, 2025 8:30:07 PM(UTC)
karelholubicka
Czech Republic
So, I was "lucky" enough that I was able to duplicate this issue and also have other measures to dig in and compare. And current status of my finding (valid on BAD machine W10+AMD580 only) is this:
From time to time (may be anything between 10 min to 1 hour) BMD driver performs something like "reset".
This concerns all cards and outputs in the machine, at one single moment.
Reason unknown, definitely it is not caused by vMix alone.
Changing AMD to nVidia did not change anything.
This reset causes interruption to playout, both video and audio, for appx 20-30 ms (1 of two frames at 1080p50).
Depending on monitoring device it may be seen as black or frozen frame + audio glitch.
After this, playout software has to "recover".
Edius (an probably OBS, MediaExpress etc.) recover without issue,
only AV sync slightly changes.
But vMix struggles. After one or two such driver "resets",
sound on vMix SDI Out is scrambled or gone.
So, vMix seems not to be primary cause, it only makes it more visible, resp. audible than other SW.
I'm copying this to BMD forum too.
Salvatore
#15 Posted : Monday, October 27, 2025 8:03:54 AM(UTC)
Salvatore
Italy
you mentioned that you’re able to reproduce the issue and that the BMD driver performs a reset after some time.
Our assumption is that the DeckLink cards and vMix may cause a sync problem between video and audio when the external output is started, and that after several start/stop cycles they synchronizes properly. I already mentioned this earlier in this thread.
Since you issue is now reproducible,
could you please try starting and stopping the external output a few times (2–3 times) right after launching and see if it still occurs?
karelholubicka
#16 Posted : Monday, October 27, 2025 5:51:51 PM(UTC)
karelholubicka
Czech Republic
Hi, this may be another cause.
At my machine, I may turn on External output plenty of times on/off,
and it always plays normally and in (reasonable) sync,
until mysterious reset occures and audio goes scrambled or off.
And after that, simple off/on cycle of external out returns audio with sync.
"BMD driver reset" (in my cause) does not depend on vMix at all,
it happenes even without vMix launched.
karelholubicka
#17 Posted : Sunday, November 2, 2025 2:26:05 AM(UTC)
karelholubicka
Czech Republic
Hi all.
I solved the audio on external Decklink output cutout.
TL;DR - update BIOS.
First, I isolated, that problem was caused by Decklink driver,
which somehow "resets", causing dropping frame(s) and scrambling audio.
This happened to Decklink inputs too (therefore all capturing, editing apps etc).
I updated BMD Status monitor SDK app, which proved, that when "reset" happenes,
the driver does not report any dropped frames nor playback changes.
Very unusual.
While the computer is 6 years old, I did not remember it had such Decklink issues before.
But there was faulty motherboard change/replacement/update appx a year ago,
after which - coincidentally - I did not have to use the Decklink audio out.
As I had no other clue, I went to BIOS update.
I did not update when I replaced the motherboard, since there was strong warning
"Do not update, if your computer works OK".
Also, there was no mention that the update should fix some performance or stability issues.
But for now, to me the PC was not "OK", so I updated.
And voila - Decklink resets are gone. So are playback issues with vMix.
I just now finished playback of 1 hour timecoded file out of vMix.
During that hour, 18 frames were duplicated due to clock difference between vMix and Decklink.
This is 0,01% accuracy, not great, not bad either.
Except these 18 quiet frames, all audio played out well. Did not drop out.
