Here is an illustration of the GT bounding issue I posted about above. I've adjusted the lighting in the still frame to make it standout (we hid it by using a dark background when the demo was recorded).  GT-empty-bounding-issue-small.png (289kb) downloaded 3 time(s).
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
Ive just bought the 4k license and I'm working with "mix input" (great new feature). I've a problem: I load a video in preview of mix input and when I cut or fade to the output, the video doesn't start (I must start it manually in its own input). It is a correct behavior or I'm missing something?
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
Originally Posted by: spino  Ive just bought the 4k license and I'm working with "mix input" (great new feature). I've a problem: I load a video in preview of mix input and when I cut or fade to the output, the video doesn't start (I must start it manually in its own input). It is a correct behavior or I'm missing something? That is the intended behaviour. There are certain restrictions on the mix input. RestrictionsThe Mix input is intended as a basic video mixer/switcher only, as a result the following features are not available: - Stinger transitions
- Overlays (inputs can still be setup manually through the standard input MultiView feature)
- Auto play/pause/restart of inputs. (This is to prevent unexpected situations where inputs are used by both the main mix and an input mix)
- Audio auto mixing.
- T-Bar transitions
Originally Posted by: Lennart  Originally Posted by: spino  Ive just bought the 4k license and I'm working with "mix input" (great new feature). I've a problem: I load a video in preview of mix input and when I cut or fade to the output, the video doesn't start (I must start it manually in its own input). It is a correct behavior or I'm missing something? That is the intended behaviour. There are certain restrictions on the mix input. RestrictionsThe Mix input is intended as a basic video mixer/switcher only, as a result the following features are not available: - Stinger transitions
- T-Bar transitions
Thank you Lennart. I think that auto play coul be a good improvement. Obviously the video would start for main mix too but if mix input is selected I don't see what could be the problem. Anyway I respect the choice of programmers.
HELP !!! Using version 23.0.0.51, trial licence. Not sure if this is a new bug, or this has always been there... Trying to delay the input video stream that I'm receiving using RTSP by ~14 sec: Input Settings => Advanced => Delay => 420 frames After doing this, the stream is delayed, but I see ghosting coming through in real-time! That is - "the ghost" will appear real-time where the delayed video will be in 14 secs This happens continuously. But this does NOT happen if the Input is a built-in Web Camera. Can anyone else try to reproduce it, and confirm, please?  Ghost1.jpg (239kb) downloaded 2 time(s).UPDATE: What I learned from Tech Support: "Video Delay feature is not actually supported on VLC Stream inputs". Instead, there is a different method - using a Buffer on the General Tab when adding an Input. This way you can delay video up to 10 seconds.
I know this thread is not for feature requests, but I just realized I forgot to request it before and it is kinda important mobdro tubemate
Joined: 6/25/2020(UTC) Posts: 1  Location: KEW GARDENS
Originally Posted by: admin  hi im new here, just want to know i have a msi laptop, for some reasons everytime i load up vmix it freezez all the time:( is there a solution for this?
Joined: 1/13/2010(UTC) Posts: 5,338  Location: Gold Coast, Australia Was thanked: 4741 time(s) in 1627 post(s)
vMix 23 will be a free update for those that have purchased after January 1st 2018 or if you've purchased a 12 month upgradeā¦in the last 12 months. For more information about vMix, just head to vMix.com! mcdvoice mybkexperience
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
if you put a triggle, ontransitionin or ontransitionout -> cut(any transition) -> any source, 500, 2000(or any delay) not work, if change to play, or audio work but not using transition, i test in .62 and .65 in two diferent pc
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
 1 user thanked dmwkr for this useful post.
