2 Pages<12
richardgatarski
#21 Posted : Friday, February 28, 2020 8:32:08 PM(UTC)
richardgatarski
Here is an illustration of the GT bounding issue I posted about above. I've adjusted the lighting in the still frame to make it standout (we hid it by using a dark background when the demo was recorded).
spino
#22 Posted : Sunday, March 15, 2020 9:31:56 PM(UTC)
spino
Italy
Was thanked: 21 time(s) in 13 post(s)
Ive just bought the 4k license and I'm working with "mix input" (great new feature). I've a problem: I load a video in preview of mix input and when I cut or fade to the output, the video doesn't start (I must start it manually in its own input). It is a correct behavior or I'm missing something?
Lennart
#23 Posted : Sunday, March 15, 2020 10:23:36 PM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
That is the intended behaviour. There are certain restrictions on the mix input.
Restrictions
The Mix input is intended as a basic video mixer/switcher only, as a result the following features are not available:
  • Stinger transitions
  • Overlays (inputs can still be setup manually through the standard input MultiView feature)
  • Auto play/pause/restart of inputs. (This is to prevent unexpected situations where inputs are used by both the main mix and an input mix)
  • Audio auto mixing.
  • T-Bar transitions
spino
#24 Posted : Monday, March 16, 2020 2:53:43 AM(UTC)
spino
Italy
Restrictions
  • T-Bar transitions
Thank you Lennart. I think that auto play coul be a good improvement. Obviously the video would start for main mix too but if mix input is selected I don't see what could be the problem.
Anyway I respect the choice of programmers.
Leonid
#25 Posted : Tuesday, April 21, 2020 1:20:23 AM(UTC)
Leonid
Canada
HELP !!! Using version 23.0.0.51, trial licence.
Not sure if this is a new bug, or this has always been there...
Trying to delay the input video stream that I'm receiving using RTSP by ~14 sec:
Input Settings => Advanced => Delay => 420 frames
After doing this, the stream is delayed, but I see ghosting coming through in real-time!
That is - "the ghost" will appear real-time where the delayed video will be in 14 secs
This happens continuously. But this does NOT happen if the Input is a built-in Web Camera.
Can anyone else try to reproduce it, and confirm, please?
UPDATE:
What I learned from Tech Support: "Video Delay feature is not actually supported on VLC Stream inputs".
Instead, there is a different method - using a Buffer on the General Tab when adding an Input.
This way you can delay video up to 10 seconds.
krankins
#26 Posted : Thursday, June 25, 2020 7:13:08 PM(UTC)
krankins
India
I know this thread is not for feature requests, but I just realized I forgot to request it before and it is kinda important mobdro tubemate
cr!s
#27 Posted : Thursday, June 25, 2020 11:11:09 PM(UTC)
cr!s
Originally Posted by: admin Go to Quoted Post
vMix 23 has been released!
Visit the download page below to download and view all the changes:
http://www.vmix.com/software/download.aspx
Feedback
Please report any bugs or questions in this thread.
Thanks,
hi im new here, just want to know i have a msi laptop, for some reasons everytime i load up vmix it freezez all the time:( is there a solution for this?
#28 Posted : Thursday, June 25, 2020 11:27:57 PM(UTC)
Was thanked: 4741 time(s) in 1627 post(s)
Please drop us an email.
https://www.vmix.com/contact-us.aspx
nikkinemo95
#29 Posted : Thursday, September 3, 2020 10:11:03 PM(UTC)
nikkinemo95
India
vMix 23 will be a free update for those that have purchased after January 1st 2018 or if you've purchased a 12 month upgrade…in the last 12 months. For more information about vMix, just head to vMix.com! mcdvoice mybkexperience
dark_ata
#30 Posted : Tuesday, October 20, 2020 4:36:18 AM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
if you put a triggle, ontransitionin or ontransitionout -> cut(any transition) -> any source, 500, 2000(or any delay) not work, if change to play, or audio work but not using transition, i test in .62 and .65 in two diferent pc
dmwkr
#31 Posted : Tuesday, October 20, 2020 4:47:39 AM(UTC)
dmwkr
See:
https://www.vmix.com/help23/Triggers.html
"Note that in order to prevent loops, transition effects have no effect for OnTransitionIn or OnTransitionOut."
thanks 1 user thanked dmwkr for this useful post.
dark_ata on 10/20/2020(UTC)
2 Pages<12
