LiveP
#1 Posted : Thursday, April 16, 2020 9:22:10 PM(UTC)
LiveP
Singapore
Hi all,
Need some help here
We are using vmix call.
- sending callers BUS A mix for returns
- using a wired microphone to push to talk to speakers by Bus A
- configured wired microphone to off MASTER sends
We can push A on the wired microphone input to speak to callers
What shortcut can be done to trigger the wired microphone to on bus A ?
Its only working with a mouse click now.
dmwkr
#2 Posted : Thursday, April 16, 2020 10:12:50 PM(UTC)
dmwkr
"AudioBusOn" / "AudioBusOff", resp. "AudioBus" for toggle
LiveP
#3 Posted : Thursday, April 16, 2020 11:40:44 PM(UTC)
LiveP
Singapore
Does the audio bus on/off allows to select input? For shortcut
dmwkr
#4 Posted : Friday, April 17, 2020 12:03:39 AM(UTC)
dmwkr
Yes, for value (=bus M, A-G) and input. See:
https://www.vmix.com/hel...utFunctionReference.html
plizon
#5 Posted : Friday, April 17, 2020 7:40:56 PM(UTC)
plizon
you can also use the function Videocallaudiosource and set it to BUSA and create another shortcut to revert it to master.
When using this function, you can have a separate talkback for each vmix call with a pair of shortcuts for each call
