Push To Talk Shortcuts for Input for Vmix callers talkback
Joined: 4/15/2020(UTC) Posts: 15  Location: Singapore Thanks: 4 times
Hi all,
Need some help here
We are using vmix call.
- sending callers BUS A mix for returns - using a wired microphone to push to talk to speakers by Bus A - configured wired microphone to off MASTER sends
We can push A on the wired microphone input to speak to callers
What shortcut can be done to trigger the wired microphone to on bus A ?
Its only working with a mouse click now.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
"AudioBusOn" / "AudioBusOff", resp. "AudioBus" for toggle
Does the audio bus on/off allows to select input? For shortcut
Joined: 4/8/2019(UTC) Posts: 21  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
you can also use the function Videocallaudiosource and set it to BUSA and create another shortcut to revert it to master. When using this function, you can have a separate talkback for each vmix call with a pair of shortcuts for each call
