givros
#1 Posted : 5 years ago
givros
Hello
I am facing the following proplem. I want to make a 6 caller conference but i also want to record them with the multirecorder. But when i start recording in mp4 *even if it is selected only one input (caller) i get about 21 frames droped every second.
I tried everyother option for recording but i get the same result I even tried two other computer with different confiquration
Does anyone have any idea
Thank you in advance
gre2gor
#2 Posted : 5 years ago
gre2gor
Slovenia
Was thanked: 17 time(s) in 6 post(s)
I noticed the same thing. Multicoder recording of output is ok, separate calls have dropped frames. My system is set to 1080p25, callers have usually something about 640x480 30fps.
givros
#3 Posted : 5 years ago
givros
This happenss when you choose low bandwidth. Then the input is 640x360 but there is no dropped frames but otherwise i still havent found any solution3
