Hello I am facing the following proplem. I want to make a 6 caller conference but i also want to record them with the multirecorder. But when i start recording in mp4 *even if it is selected only one input (caller) i get about 21 frames droped every second. I tried everyother option for recording but i get the same result I even tried two other computer with different confiquration Does anyone have any idea Thank you in advance
Joined: 12/14/2018(UTC) Posts: 81 Was thanked: 17 time(s) in 6 post(s)
I noticed the same thing. Multicoder recording of output is ok, separate calls have dropped frames. My system is set to 1080p25, callers have usually something about 640x480 30fps.
This happenss when you choose low bandwidth. Then the input is 640x360 but there is no dropped frames but otherwise i still havent found any solution3
