Joined: 8/8/2019(UTC) Posts: 26  Location: Georgia Was thanked: 2 time(s) in 2 post(s)
Is there a way from within a script to find out which input is displayed in the Preview and Output windows? I have a 2 camera system and I could better automate their control if I had that info available.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
YES.
XML API Check out scripting for dummies post (vb.net scripting)
Thanks doggy.. Here is the code
dim PreviewIn as string 'holds the Input number in the Preview window dim ActiveIn as string 'holds the Input number in the Active window dim PreviewTitle as string 'holds the Title in the Preview window dim ActiveTitle as string 'holds the Title in the Active window
dim xml as string=API.XML() dim x as new system.xml.xmldocument x.loadxml(xml)
ActiveIn= (x.SelectSingleNode("//active").InnerText) PreviewIn= (x.SelectSingleNode("//preview").InnerText) PreviewTitle = (x.SelectSingleNode("//input[@number='"& PreviewIn &"']/@title").Value) ActiveTitle = (x.SelectSingleNode("//input[@number='"& ActiveIn &"']/@title").Value)
console.writeline(PreviewIn) console.writeline(ActiveIn) console.writeline(PreviewTitle) console.writeline(ActiveTitle)
There you go :-) Why not ad this little tidbit to the scripting for dummies post ? and use the 'choose language for syntax highlighting' for the code Code:and use the 'choose language for syntax highlighting' for the code
