john30120
#1 Posted : Friday, April 17, 2020 1:57:57 AM(UTC)
john30120
Is there a way from within a script to find out which input is displayed in the Preview and Output windows? I have a 2 camera system and I could better automate their control if I had that info available.
#2 Posted : Friday, April 17, 2020 2:05:29 AM(UTC)
YES.
XML API
Check out scripting for dummies post
(vb.net scripting)
john30120
#3 Posted : Saturday, April 18, 2020 1:39:42 AM(UTC)
john30120
Thanks doggy.. Here is the code
dim PreviewIn as string 'holds the Input number in the Preview window
dim ActiveIn as string 'holds the Input number in the Active window
dim PreviewTitle as string 'holds the Title in the Preview window
dim ActiveTitle as string 'holds the Title in the Active window
dim xml as string=API.XML()
x.loadxml(xml)
ActiveIn= (x.SelectSingleNode("//active").InnerText)
PreviewIn= (x.SelectSingleNode("//preview").InnerText)
PreviewTitle = (x.SelectSingleNode("//input[@number='"& PreviewIn &"']/@title").Value)
ActiveTitle = (x.SelectSingleNode("//input[@number='"& ActiveIn &"']/@title").Value)
console.writeline(PreviewIn)
console.writeline(ActiveIn)
console.writeline(PreviewTitle)
console.writeline(ActiveTitle)
#4 Posted : Saturday, April 18, 2020 1:53:43 AM(UTC)
There you go :-)
Why not ad this little tidbit to the scripting for dummies post ?
and use the 'choose language for syntax highlighting' for the code
Code:
Similar Topics
VB Scripting: CHR(#) not recognized (General Discussion)
by TBacker 3/5/2021 8:29:03 AM(UTC)
VB Scripting Function (General Discussion)
by MatthiasHH 9/22/2020 10:40:39 PM(UTC)
