Zoom updated- now desktop capture is white screen
Joined: 5/1/2019(UTC) Posts: 34  Location: Indianapolis Thanks: 4 times
When I started zoom today, it made me wait a short bit while it updated. Then in vMix, I went to my desktop capture input, and right clicked it and selected the meeting in progress. White screen. I tried other sources, full screens, open applications, browser windows- everything works as expected. But not Zoom. It's the one and only thing that is now a white screen... and this is a saved config file that has worked with Zoom forever. (Until today's update)
As a workaround, I was able to move the zoom window to a 2nd monitor, share that full monitor, and then crop and zoom back into the zoom window. This will work for now- but long term is not a solution I can use.
Has anyone seen this before. I am certain it's 100% Zoom's fault- and could be something to do with them trying to prevent this new zero-day exploit that allows hackers to watch your zoom conferences? But want to see what I can do to get it back. (and know that a talk with zoom is where this is likely headed- but know that these forums will be full of people who understand what I'm trying to do long before zoom tech support will)
vMix 21.0.0.61 x64 Windows 10 Home
Joined: 4/8/2020(UTC) Posts: 10  Location: Belgrade Was thanked: 1 time(s) in 1 post(s)
Hello. You can watch my tutorial and do everything just like I did in video. For me this is the best way transfering zoom to vmix with using just one display.
 1 user thanked vmixusersrb for this useful post.
Originally Posted by: vmixusersrb  Hello. You can watch my tutorial and do everything just like I did in video. For me this is the best way transfering zoom to vmix with using just one display. THAT IS AWESOME AND THAT IS WHY I POSTED HERE FIRST! I can't test it again until Monday- but I bet the Zoom update changed that setting. Thank you so much for this- looks like a super simple fix!
Originally Posted by: themann00  Originally Posted by: vmixusersrb  Hello. You can watch my tutorial and do everything just like I did in video. For me this is the best way transfering zoom to vmix with using just one display. THAT IS AWESOME AND THAT IS WHY I POSTED HERE FIRST! I can't test it again until Monday- but I bet the Zoom update changed that setting. Thank you so much for this- looks like a super simple fix! OK, but I made this working on 23 version of vmix, I don't know will this work on your version...
