GT
Countdown to stream graphic
Joined: 11/22/2018(UTC) Posts: 94  Location: Worthing Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Hi I have a countdown to stream title using the following text
{0:3:45:00PM|h:mm:ss}
This will show the time left to the auction at 3.45 pm in hours:minutes:seconds.
The problem is when it gets to less then an hour to go the hours display 12 not 0.
I therefore have to fade off the graphic just before an hour to go and change the text to {0:3:45:00PM|mm:ss}, then fade back when the hour mark has passed. Is there some way to change this with the text or is it a slight glitch in the way title editor works?
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Have you tried an 'H' instead of the 'h' in your text? Can't test now, but I think it should work.
Thank you very much, now working.
I want to do a 24 hour countdown. How do I write this script?
Thank you for the answer
Joined: 12/27/2012(UTC) Posts: 5,520  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: FrankLeggett  Hi I have a countdown to stream title using the following text
I therefore have to fade off the graphic just before an hour to go and change the text to {0:3:45:00PM|mm:ss}, then fade back when the hour mark has passed. Is there some way to change this with the text or is it a slight glitch in the way title editor works? Have you tried 24hr time setting instead of AM - PM ?
What does the script say about you AM-PM? I want the clock to start like this 24.00.00 23.59.59 23.59.58
Originally Posted by: tomistravel  What does the script say about you AM-PM? I want the clock to start like this 24.00.00 23.59.59 23.59.58 What script are you talking about?
 countdown.png (121kb) downloaded 0 time(s).{0:19:19:00|HH:mm:ss } How do I make this script give me a 24 hour count?
Originally Posted by: tomistravel  What does the script say about you AM-PM? I want the clock to start like this 24.00.00 23.59.59 23.59.58 in this case use the countdown (from 23:59:59) which is the max time one can countdown instead of the clock wich will countdown to a certain time of day
I found a solution. I had to go into Settings and there I set countdown.  countdown1.png (93kb) downloaded 0 time(s).
Originally Posted by: tomistravel  I found a solution. I had to go into Settings and there I set countdown.
That's what i suggested in post before this !
GT
