FrankLeggett
#1 Posted : Wednesday, April 15, 2020 12:32:47 AM(UTC)
FrankLeggett
Hi I have a countdown to stream title using the following text
{0:3:45:00PM|h:mm:ss}
This will show the time left to the auction at 3.45 pm in hours:minutes:seconds.
The problem is when it gets to less then an hour to go the hours display 12 not 0.
I therefore have to fade off the graphic just before an hour to go and change the text to {0:3:45:00PM|mm:ss}, then fade back when the hour mark has passed. Is there some way to change this with the text or is it a slight glitch in the way title editor works?
dmwkr
#2 Posted : Wednesday, April 15, 2020 3:30:29 AM(UTC)
dmwkr
Have you tried an 'H' instead of the 'h' in your text? Can't test now, but I think it should work.
FrankLeggett
#3 Posted : Wednesday, April 15, 2020 7:47:00 PM(UTC)
FrankLeggett
Thank you very much, now working.
tomistravel
#4 Posted : Thursday, April 16, 2020 2:26:04 AM(UTC)
tomistravel
Romania
I want to do a 24 hour countdown.
How do I write this script?
Thank you for the answer
#5 Posted : Thursday, April 16, 2020 2:36:43 AM(UTC)
Have you tried 24hr time setting instead of AM - PM ?
tomistravel
#6 Posted : Thursday, April 16, 2020 2:47:06 AM(UTC)
tomistravel
Romania
What does the script say about you AM-PM?
I want the clock to start like this
24.00.00
23.59.59
23.59.58
#7 Posted : Thursday, April 16, 2020 2:56:59 AM(UTC)
24.00.00
23.59.59
23.59.58
What script are you talking about?
tomistravel
#8 Posted : Thursday, April 16, 2020 3:32:09 AM(UTC)
tomistravel
Romania
How do I make this script give me a 24 hour count?
#9 Posted : Thursday, April 16, 2020 3:43:01 AM(UTC)
#10 Posted : Thursday, April 16, 2020 3:46:41 AM(UTC)
24.00.00
23.59.59
23.59.58
in this case use the countdown (from 23:59:59) which is the max time one can countdown instead of the clock wich will countdown to a certain time of day
tomistravel
#11 Posted : Thursday, April 16, 2020 6:08:16 AM(UTC)
tomistravel
Romania
I found a solution. I had to go into Settings and there I set countdown.
#12 Posted : Thursday, April 16, 2020 6:33:08 AM(UTC)
That's what i suggested in post before this !
