I have an Aver CAM520 usb connected and every time I do a recording or go live the camera lags badly! I use my iPhone 11 and it works fine! I use the same CAM520 in obs and it works fine! Please help me! Thanks!
@ surob
Long story short: vMix does not support/like h.264 USB 2 HD camera signals.
So in my older computer, it works, but the reason I changed or upgraded is that my cpu was at 100 percent always while using vmix. the video card was a 256 mb and it could not handle the load. This sucks.
I've used the CAM520 with vMix without issue. I reviewed it here: https://www.mgraves.org/...ce-camera-system-part-2/Just make sure that you select video encoding type MJPEG when setting up the source. Using H264 will incur the encoding delay associated with the GOP length.
Thank you MJ..that works, I appreciate your input.
