Joined: 4/12/2020(UTC) Posts: 11  Location: London Thanks: 2 times
When playing a video as an input there is a bar below the preview or programme windows which allows you to scrub left or right when the video is paused. Is there any way to map this to a keyboard shortcut so that a rotary control such as a Griffin PowerMate can be used for scrubbing?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: davenv  When playing a video as an input there is a bar below the preview or programme windows which allows you to scrub left or right when the video is paused. Is there any way to map this to a keyboard shortcut so that a rotary control such as a Griffin PowerMate can be used for scrubbing? https://forums.vmix.com/...controling-video-playersThere is a SetPosition Shortcut , so with some imagination one could create something
Thank you for the link: I had seen that discussion. I'm not looking for precision, just a way to do as much - or as little - on the keyboard with the active video as I can with the mouse.
Thank you for your excellent suggestion: when I attempt this, however, I get an error message: "Duration is not a number or is invalid." I'm new to this program so I'm not sure what syntax it's expecting.
After restarting everything this is now functioning,- thank you very much. There must have been a glitch.
