GT
GT Designer - Importing it into VMIX
Okay so, I've made my title in GT Designer, but I can't figure out how to get the template back over into VMix... In the tutorial it looks like it was there automatically, but mine is not. I've tried saving it but it saves as a gtzip file, which apparently vmix doesn't open, and I can't figure out any way to export as a WMF.... What am I missing? Apparently this should be simple but I've been trying for quite a while. Supposed it was time to ask for help.
Thanks so much, Chris
If anyone has any insight, I was hoping to get this figured out to implement the scripture overlay for our Easter service tomorrow 😅
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
You should be able to create a "Title" input in vMIx and load your .gtzip file from wherever you saved it when you created it in GT Tile Designer. There's no reason to convert to WMF ?
Originally Posted by: raugert  You should be able to create a "Title" input in vMIx and load your .gtzip file from wherever you saved it when you created it in GT Tile Designer. There's no reason to convert to WMF ? Can you tell where I'm going wrong? I'm just trying to add the .gtzip, but I get an error every time: https://www.loom.com/sha...e30b4e2380910fe2d0221e60
It seems like your .gtzip file may be corrupt for some reason. But before redoing your .gtzip file, you should delete that particular "Title" input in vMix and create new one. Then load your .gtzip file into the new input. I have had instances in the past where just creating a new input fixed the problem..
Just taking a shot in the dark here.. or
If you are still having problems with the GT Designer, you might just use the Legacy .xaml title designer. Seeing as you don't have any animations, the GT features aren't quite as important. It would probably get you by for tomorrow and at least get your scriptures running..
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
GT requires the 64bit version of Windows installed. It looks like you have Windows 8 32bit which is why it is not working unfortunately...
Thanks everyone! The problem ended up being that I was using the 32 bit version of vMix, rather than the 64 bit. My windows 8 was actually 64bit, but I went ahead and upgraded it to windows 10 for free too ( based on this article). Didn't get it all figured out in time for Sunday morning, but I'm looking forward to using what I've learned for tomorrow's drive-in service recording/stream. Thanks again, Chris
GT
