SRT
SRT What am I doing Wrong? SOLVED
Joined: 6/16/2015(UTC) Posts: 193   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
I am trying to set up a SRT link between two vMix systems over a WAN, thought I was going mad with all my NATing in my router, so decided to try SRT just on the local LAN, with just two machines plugged into the switch. But I just cant get a connection between the two machines, tried Listener/Caller, Caller/Listener, and Rendezvous/Rendezvous - nothing works. I have turned of the firewalls in both PC's. Sending PC... 10.1.9.41  image1.JPG (38kb) downloaded 1 time(s).Receiving PC... 10.1.9.43  image2.jpg (58kb) downloaded 1 time(s).
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
I don't believe that Rendezvous works on a LAN.
Also try a Caller to Listener connection, and turn off the hardware encoder and low power and see if it works and repost your screen cap.
Good Luck, Steve
I discoverd I could get it to work the opposite way round i.e send from the remote, back to the master. Which also worked absolutely perfectly across my WAN. I decided that the only thing that was common was my Master vMix was not sending SRT to anything, i then realised I could get every machine I have access to communicate perfectly with SRT, it was just a single machine.
Solution
Reinstalled vMix (23.0.0.50) Installed MAGIC YUV Codec (As this had been missed from the original install - not sure why)
Everything Worked. Maybe something in the SRT encoder needs access to that codec... not sure why as SRT is h264/265
SRT
