kgoodyer
#1 Posted : Monday, April 6, 2020 4:18:25 PM(UTC)
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
I am trying to set up a SRT link between two vMix systems over a WAN, thought I was going mad with all my NATing in my router, so decided to try SRT just on the local LAN, with just two machines plugged into the switch. But I just cant get a connection between the two machines, tried Listener/Caller, Caller/Listener, and Rendezvous/Rendezvous - nothing works. I have turned of the firewalls in both PC's.
Sending PC... 10.1.9.41
Receiving PC... 10.1.9.43
stevespaw
#2 Posted : Monday, April 6, 2020 11:41:54 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
I don't believe that Rendezvous works on a LAN.
Also try a Caller to Listener connection, and turn off the hardware encoder and low power and see if it works and repost your screen cap.
Good Luck,
Steve
kgoodyer
#3 Posted : Tuesday, April 7, 2020 12:01:17 AM(UTC)
kgoodyer
I discoverd I could get it to work the opposite way round i.e send from the remote, back to the master. Which also worked absolutely perfectly across my WAN. I decided that the only thing that was common was my Master vMix was not sending SRT to anything, i then realised I could get every machine I have access to communicate perfectly with SRT, it was just a single machine.
Solution
Reinstalled vMix (23.0.0.50)
Installed MAGIC YUV Codec (As this had been missed from the original install - not sure why)
Everything Worked. Maybe something in the SRT encoder needs access to that codec... not sure why as SRT is h264/265
